Evo V Build/Project thread
Mikeyc
Mikeyc
Oh a jig I'm not sure if they will be using one but they are very thorough, thanks for your help mate I've got some work to do this morning and ill do some research into these :)
Any advice is much appreciated mate ;)
No Worries Mikey as 2 heads are better than one:razz: Plus i've been there with many land rover's:)
Mikeyc
Mikeyc
Spoke to a guy who works a lot with metals today and he said he has heard a lot of complaints with acid dipping so glad I didn't go down that route,
He said best to do as I am and inject wax oil just like you said James ;)
Dropped all of the metal parts to him today for powder coating so the resto is coming along nicely :)
Mikeyc
Mikeyc
Little update on the car
The underside has been taken back also I will get some pictures
Then etch primer, primer, rub down, stonechip and then painted white.
The prep on exterior panels will begin shortly
That's a excellent job going on there. Metal looks good too ! :)
Mikeyc
Mikeyc
Updated Spec:
2.3 Stroker Built By Nick at AMS Engineering
Je pistons 86mm
Manley I beam rods
Eagle crank
ACL Main bearings
ACL Big end Bearings
Head ported and polished
Cosworth Head gasket
Cat Cams Valve Springs
Crower Cams
Vernier Pulleys (unsure on brand but will update)
Arp Head stud kit
Arp rod bolts
Gtx3582r stock frame turbo (will be changing to full frame) so this will be for sale soon and is brand new
Racetech tubular exhaust manifold
Jasma exhaust 3" turbo back
Forge Race intercooler and custom boost pipework
Forge BOV
Tial Wastegate
Exedy triple plate clutch
Standard 5 Speed GSR gearbox
Standard Diffs
Apexi Ecu
Apexi FC power commander
Rota GTR alloys
Standard Brembo brakes
d2 coilovers (which are being sold and replaced with...ohlins or maybe nitrons)
Full superpro polybush kit on the way :)
Coming on, I've been rubbing down paint in my engine bay today. Sore but smooth fingertips :)
