I thought that hydra was the way forward regarding bigger power engine builds:confused: Ah well it's bought now so would be ashame not to fit it:blush::whistling:
if its not fitted id sell it on imo get some cash back for it, russ on here is running 600+ on standard ecu
So let me get this right then I can run without a maf on standard ecu using ecutec:confused:
so thats a dont do it then? :whistling::whistling:
I believe AndyF was running 1.5bar on Launch with only -15 and Russ/Cossie1 was not going more than -10 on launch because of the boost level he was getting and lighting up all 4 wheels on launch :wtf:
you see proper antilag on rally car that probably run that type of negative timing through gear changes, i would like to know how often the turbos are changed?
chrishfq300
chrishfq300
if your gonna kill it you may as well look cool in the process
Every stage LMAO :disgusted:
when i played i put the air injection times up and put -40 across the whole map, on standard 9.8 hotside turbo, saw 1.5+ and first time i needed new pants
am i right in saying rob Tephra V7 for 7/8/9 has launch maps holy sh*t!!!!!???
chrishfq300
chrishfq300
Rob have you figured out how to get my anti lag effect of launch yet? :whistling:
