So why have them if it damages your turbo and high exhaust temps, apart from the obvious?
stevolution2010
stevolution2010
so if u just let tham take there course naturally i.e just drive the car then itll be ok?
Think I'll give them a miss when I get my Hydra fitted then:cry::cry:
stevolution2010
stevolution2010
i suppose it would be, but ive seen people there in the car park banging away for a solid 30 mins :wtf::wtf:
nah i wouldnt do that,sometimes mine backfires when im driving usually after ive changed gear
over fueling maybe?
ive spent 2k plus on a turbo no way id be using them imo, your having a hydra, youd get massive p&b actually probly real antilag!, what evo ya got
why not using the existing ecu its very capable?
+1 :hm:
When the std ecu is so capable nowadays with all the improvments with features galore :p Why go for an aftermarket ecu??:cry:
I bought it off MartinW, as I want to up the power eventually also run maflees so I can fit my ruddy carbon airbox, also gonna have throttle kicker:)
SD is availible for the 9,.........? rob? and mega power can be acheieved on standard ecu
You can run sd no prob on the std ecu
Power is not related to ecu capability. Don't understand why people keep asking if the std ecu will be able to handle 'x' amount of bhp power. Its just 'computing' power in the ecu and std is more than capable.
They both do the same job just slightly differently with programming.....
Bigger :eek: BANGS
You already know that. You asked the other day :whistling:
Damn you Si :p:p
I thought that hydra was the way forward regarding bigger power engine builds:confused: Ah well it's bought now so would be ashame not to fit it:blush::whistling:
