what are the implications to taking the timing to -30?
i would say 1bar + static boost, destroyed ear drums and a large bill for a ne turbo a few hours later:disgusted::disgusted:
I thought that hydra was the way forward regarding bigger power engine buildsAh well it's bought now so would be ashame not to fit it:blush::whistling:
if its not fitted id sell it on imo get some cash back for it, russ on here is running 600+ on standard ecu
So let me get this right then I can run without a maf on standard ecu using ecutec![]()
so thats a dont do it then? :whistling::whistling:
yes.... i did it once poop came out
you see proper antilag on rally car that probably run that type of negative timing through gear changes, i would like to know how often the turbos are changed?
Every stage LMAO :disgusted:you see proper antilag on rally car that probably run that type of negative timing through gear changes, i would like to know how often the turbos are changed?
I believe AndyF was running 1.5bar on Launch with only -15 and Russ/Cossie1 was not going more than -10 on launch because of the boost level he was getting and lighting up all 4 wheels on launch :wtf:
am i right in saying rob Tephra V7 for 7/8/9 has launch maps holy sh*t!!!!!???
Yes they do ...am i right in saying rob Tephra V7 for 7/8/9 has launch maps holy sh*t!!!!!???
Still working on this. As not sure how the launch map works. As I don't have a 7/8/9 to test regularly :hm:Rob have you figured out how to get my anti lag effect of launch yet? :whistling:
is it true evo 9's has launch as standard ????
