Rob - does this mean i can have switchable maps turned on?! :whistling:
Yes just as you asked before and then changed your mind :whistling:
Now you after them again :wtf:
Cut the boost altogether??? :hm:Keeping you on your toes. Stupid question maybe but... is it possible to alter the rpm at which the boost hits or cut the boost altogether?
You mean turn the boost off...basically turning it into a NON turbo 2ltr :disgusted:
Thats just not right :disgusted: :disgusted: :wtf: :wtf:Thats exactly what I mean![]()
havnt got a ucking clue what you lot are going on about
any one fancy a biscuit
No thx![]()
Not even going to entertain your thoughts of flicking the turbo OFF. Go by another carIf you can switch the map while driving down the road with the flick of a button then it makes perfect sense!
You have the correct xml to go with the tephra v7?cant get v7 to work on ecuflash, is there an evo 8 base or is it derived from a evo 7 base xml?
Not even going to entertain your thoughts of flicking the turbo OFF. Go by another car![]()
The customer is always right!!
I'm just thinking with a trip to the Lake District, Edinburgh, Liverpool a few times and Japfest @ coombe it would be a worthwhile happy pocket solution
yes you can
