What boost controller have you got? To test actuator put a single piece of hide between turbo and actuator and it should boost way less than 1 bar. That will test that. As for the crank walk from what I gather the main bearings in the middle of the crank wear and the crank walks from side to side
They have no thrust bearing, there face fit so the wear is directly on the block face
