Hi all! Well i've had a bit of a stand down from the evo for a while to concentrate more on work
But now i've had a bit more free time, i've managed to get a few more bits done
One thing that always bugged me since i owned the car was the noise of that bloody 044 pump in the engine bay, it sounds like a ****ed off wasp so have decided to move it into the boot as well as the battery. A fair bit of wiring to sort out, but i've finally sorted it
First off was to de-pressurise all the fuel system and pull it all away. I bought an Aeromotive FPR as well as a load of -6 fittings and aeroquip hose. Running the hose under the car was pretty straight forward as i cut out the metal feed hose, knocked out the plastic seats and ran the aeroquip hose in the gap
After it was all connected up and the wiring completed, i started the car up - no leaks
but i couldn't get the fuel pressure below 3.5 bar
Having researched my options, i decided to take it out on the venturi thingy in the fuel tank as it has a TINY hole in it to create the effect. Having a look at it, there isn't really much to it and i bit the bullet and drilled the hole out from 2mm to 2.5mm. I then decided to get the buckets and the hose to test to see if it still works
Well, the good news is it does! And at a low pressure too! So put it back in the car and got a 2.5 bar minimum on the fuel pressure regulator
So i can get my 3 bar base fuel pressure and its now ready for mapping! Decided to pull the car out the garage as it was covered in dust and oily hand prints and give it a blast with the pressure washer
Next step is the battery tray to be ordered from Evo Solutions
Though i know there seems to be an ongoing battle as to whether or not you need a fuse/circuit breaker in the boot for the battery or not, but i always stay on the side of caution and have invested too much time and money into this car to see it end for a failure in the cable's sheath etc. Just not worth it. So my mega fuse holder arrived today
200amp should sort it
I also fitted the switchable earth for the anti-lag on the Autronics
Just need the battery tray and a PS pump to finish her
