cam timing has been checked yea ???might sell my old ones for a few pennies now i know they were fine oh well. i didnt expect it to be fixed nothings ever that simple
looks like a new crank or engine mate. you prob read all my treads iv put up on this page so far youve most likely got piston slap mate that what happens when you run with no oil, been there done that lol:wtf:. like i said you can check the crank your self just take your oil pan and caps off and you will most likely find swarff in your pan . theres no point taking it all the way to the garage just to find out that and cost you. its gona have to be towed afterwards anyway so you might aswel check it be for it goes mate :ninja:
ill be honest mate i dont wanna be gettin much more involved inside the engine, i didnt the tappets but thats as far as ill go, im gonna take it up to the guys who do this for a living and not sell phones, i dont antisipate a small bill to fix it as much as it pains me to say but im done with throwing money at it on a hope that it works. how much roughly did it cost you to rebuild after you got the piston slap mate
is the lower cam cover and large bottom pully on or off the engine ???i cant check the bottom cam as i dont know where the timing marks are, i tried calling chris earlier but couldnt get through to see if he checked it. let me google it actually to see where they are,
+1 craig this was my first thoughts, but im no expert pal. Consider it a Expensive lesson to have learned mate .
Depends what you wanna do?, Just buy a standard replacement £3000 + I recon ??
look down at the big bottom pully and youl see it you rotate it that there is a small notch out the inside edge of it (closest to camcover) around the 1:00 position if looking from the side of the car youll see some markings on the cover that the notch in the pully wheel should line up with. at the same time the cams will also line up with the notches in the rocker cover. think of its as all 3 marks must line up at the same timeits all intact i not taken anything off apart from the inspection panel in the wheel arch mate
look for piston slap i have been through all this last month put a camera down each bore if you see any linnes going up and down y will have piston slap and if you have done compresion test and this comes out good does not mean much my compresion test read 150-150-140-140 and it still was f****d if you done all that and look in the sump i took my balace shfts out cus one was loose put it back togeather with kit and i was very p**t off the tap was still there
:wtf:start again head off then i found the problem piston slap on no 4 :blush:
