Yup, your right, cold start RPM is 1500, but if you look at the ROM you see that as the engine warms the ECU gradually uses less and less steps to bring the idle down to 850 RPM, it's not like an on/off switch, it's a gradual change, so if the thermostat or fast idle valve are partially stuck then it could cause it to idle at 1200 RPM.
Mmmmmm...................
A very good point indeed!!!
