throttle body & idle trouble
Yup, your right, cold start RPM is 1500, but if you look at the ROM you see that as the engine warms the ECU gradually uses less and less steps to bring the idle down to 850 RPM, it's not like an on/off switch, it's a gradual change, so if the thermostat or fast idle valve are partially stuck then it could cause it to idle at 1200 RPM.
Mmmmmm...................
A very good point indeed!!! :D
T
toad660
the car runs at 1200rpm constantly , it wont drop unless i plug in evoscan and go to reset the base idle at which point it brings it down to 850rpm until i come out of it and then its back up to 1200rpm.i have tried to adjust the base idle screw and its one full turn off closed .
Have you disconnected the MAF to see if there is a change???
T
toad660
no El must admit i haven't disconnected the MAF sensor cos the car is running great apart from the fast idle problem and even with it sitting at 1200rpm its constant and not erratic.
Try it in the morning buddy, once the engine has warmed up.
T
toad660
will do El , as soon as i am up its going to be the first thing i do and if am really lucky sort it out .lol. You have just got to love these cars.I know the car can be a pain but it puts a smile on my face every time i get in it, even when it idles at 1200rpm lol
Here is some input from Simon that I did not think of adding earlier:
have you disconnected the battery and left it for 5 mins and reconnected and taken for a 30 min drive to reset the ecu?
did the problem start after you removed/refitted the throttle body?
Mark Shead
Hi i have got a Evo 8 and have a problem with it the last 2 weeks, took the throttle body off to clean out ,refitted it and it will only idle at 1200 rpm now.changed the stepper motor no change, reset the TPS with evoscan no change , no air leaks , i havent got a clue why its refusing to idle at 850rpm, the only time it idles at 850rpm is when i run evoscan and press actuate it drops to 850rpm but when i come out of evoscan it goes back up to 1200rpm..................is there anyone that can help cos its doing my head in..................lol......)
Check you have the gasket on the right way round or it will cause a small airleak and high idle.
Mark
Any updates for us Ray???
Mark
The Mark Shead???
Welcome along buddy!!!
Get a Newbie Thread up already! :whistling: :whistling: :whistling:
T
toad660
yep spooners, the problem only started after the throttle body was removed and refitted..
T
toad660
now the geof checked the gasket and it was fine and fitted the same way it come off....
T
toad660
now then El Maf sensor is fine and the thermostat is working correctly, noted the suggestions from the other lads and checked the lot 3 times now with no joy mate.
T
toad660
i definitely checked the gasket mark , i know its on the right way and the gasket was in very good condition
What about taking it for a short spin afterwards to see if that helps bring it down???
