I've check the plugs out, watched them throw spark, and switched in a different set. Still nothing
I mean...as simple as it sounds, it really is the typical "NO-START condition" but it's obviously something no so typical :wtf:
-Fact: A car will still start with a hole in the block
-Fact: A car will still start up w/a bad plug or two(just run crazy).
-Fact: A dead starter will kick over on a push start
It is something else not letting this car crank over. The timing marks are lined up. The correct number of "cogs"/"ribs" on the belt are between the 2 markings on the head.
I got nothing. I mean, I can't only see so much w/the engine in the car and if the belt skipped a tooth, it should throw it off everywhere I'd imagine.
Am I missing something though, I do not see many threads on here about your Evo's skipping timing at all?? There's absolutely no one on the forums who's had a no start condition like mine before? Wow.....it was fun while it lasted I guess. Couple Spanish guys offered me trades for it as is, guess I'll take one of the civics for it. AWD turbo another time I guess.
