Yap will do...hope they can sort it outTake it back to the garage.
where bouts are u in Norwich and where did u take evo for the work
Clive has serviced mine before n all was spot on. The problem does sound a strange 1.
You slow down and oil pressure drops. That is normal but the problem you have is that it's dropping below minimum pressure. I'm guessing it's ok on cold start and only occurs once warm.
What grade of oil? If it's to thin it could cause a problem or you may have a big problem.
Is it blowing smoke?
Have you oil in the coolant?
glad you have this sorted, cant beat a manual gauge in future though to assure your not causing probs by driving it
