Oil pressure
ron23
Hi guys,just done with major fluid service,then 2 or 3 days after
My oil pressure lamp keeps on illuminating specially
When slowing down..any thoughts guys?
Thanks in advance
redevo
What oils have you used?
If you have access id get the oil pressure checked.
ron23
Thanks tommi..the garage provided the oils for
Me...after half an hour drive or when the engine is
Already hot...that oil pressure lamp keeps on
Popping
ron23
And what's worst...all the ayc were on...not my
Lucky day
ron23
where bouts are u in Norwich and where did u take evo for the work
its now been booked to ATP this coming 3rd of dec..i was hoping its not the oil pump,because the lamp only pops when slowing down after half an hr drive then its gone again when the car uis in motion..i spoke to previous garage were the fluids had been done..they were very honest since the start..i think its just the car itself (wear and tear) clive atthowe in salhouse Norwich is the name of the garage..a very decent garage too..i will give you an update after the 3rd of dec..im just hoping that its only the pressure switch.
Tom2741
Tom2741
Clive has serviced mine before n all was spot on. The problem does sound a strange 1.
You slow down and oil pressure drops. That is normal but the problem you have is that it's dropping below minimum pressure. I'm guessing it's ok on cold start and only occurs once warm.
What grade of oil? If it's to thin it could cause a problem or you may have a big problem.
Is it blowing smoke?
Have you oil in the coolant?
ron23
Yes Tom it's a bit strange...just like now driving
The car more than an hr..and the oil pressure lamp
Never pops..and the rpm is constant no fluctuations....
I'm still going to ATP to speak to Gary..I'm a bit confused
As well,fingers cross it will be a minor one.
ron23
It's not blowing smoke eighter...don't worry guys I will post everything
After seeing ATP..
ron23
as promised..went to gary of APT..quite lucky really…coz its only an oil pressure switch..and they did order it ASAP…I'm so happy forgot to ask him how much i need to pay for the parts and fitment..any ideas how much it will be?..thanks to all your replies..
glad you have this sorted, cant beat a manual gauge in future though to assure your not causing probs by driving it
ron23
Thanks fq-craigus I'm really so glad that's it's been sorted...oh btw is mechanical or electrical gauge? Which is much better when it comes to reliability and accuracy?
