Tyre pressure....advice....
Billy MR
Billy MR
What is people running
18x9 - 235/40/18
it feels a bit arse happy when hard cornering and when braking hard feels like the back end wants to come round
Think I'm running 32/32 in nitrogen
I've always run mine at 30 all round. That's with 255/35 and 235/40 tyres on and very even wear :)
What brake pads are you using ? Same for front and rear cos if not then that will make a difference :)
CHUBBYSDAD
CHUBBYSDAD
I've always run 32F 30R, thats in both my Evo's and my Subaru whatever the wheels I have had on.
30F 28R on track in the wet as well :)
Billy MR
Billy MR
I've got Godspeed discs and orange stuff pads
28/28 seems to work :)
Billy that's what I run mine at and mad a big difference on track too!! I would say different tyres need different pressures depending on make and usage!!
Billy MR
Billy MR
It's surprising really how much it helps it used to understeer a little bit
This is what I run, also it doesn't matter what size wheels tyres etc. the tyre pressure should remain the same as it is pressure that counts not quantity:)
DDS789
DDS789
You should run higher on on the front not same all round
Higher in the front like has been mentioned say 32front/30rear or even 32/28 will help with the initial turn in making it sharper as the side walls will be stiffer effectively pushing the tyres into the Tarmac more.
This will cause more oversteer so you run lower temps at the rear to keep the back end stable, just having it slightly softer helps the tyres to grab a little better when they start to slip.
The newer cars do like to go sideways more than the 4/5/6's (apart from Marios)
But tyre pressures are only a small part of the puzzle there's many many many factors that can cause the rear end to go. What suspension? Has it been geo'd? Rear ARB?
Johnno
Johnno
18x9 - 235/40/18
I would say you need to put a little camber in the rear wheels ;)
What set up you running? Wouldnt be tire pressures if you're running 32/32.
My six had the rear camber bushes gone, and zero camber. It was so fun as it was all over the place ! Now I'm running power flex bushes and 1.5 negative it's planted :)
CHUBBYSDAD
CHUBBYSDAD
Everyone has slightly different driving technique, whats good for somebody may kick out the arse of someone else's car if the approach corners differently.
My car is a totally different drive now since fitting my coil overs and having the geo. Done and will take a bit of adjusting to.
You may feel different putting more air in than you are used to/suits you, it may feel a bit skittish with more or vice a versa.
What you trying to say smasher!!!!!:whistling:
