Help on a re map please
you have a switch on your clutch peddle, you can set the parameters in the ecu so when the clutch is pushed it will drop the rpm to a set amount so that you can keep your foot planted on the throttle during gearchanges.
now thats a nice idea :) is this speed destiny any good??? you used to hear quite a bit about it but nothing latley
ah, thats another one I forgot you can do with ecuflash :blush:
SD (speed density) is just the ability to run map based and get rid of the maf sensor.
straight forward on evo 9's, earlier evos need sensors off the 9 inlet (inlet temp and map)
so wots the benifits of removing the maf?? is it worth doing and any gains ?
in most cases no its not really worth doing, it provides less airflow restriction for big power (but as we know people are running 600+ with the maf)
one added benefit is a lot smoother on lift off/gear changes (as evos can suffer from a little judder in this area)
judder i know the feeling :mad::mad: ill leave it how it is then, thanks for the info for my self and the op of this thread :wub:
jackofq340
Yeah thanks alot to all,I love this forum has always been a great help! So to recap I really need a panel filter,fuel pump befor I go for a map to make it worth it? No one answers if I need my dv to be recitculating for mild anti lag? I think when I get a map I will have mild anti lag and the engine safety feature,and possibly launch control in the future when a new clutch is needed.if any one can give me a price for this it would be a great help
you can have launch just dont launch it :) i could listen to sponners all day with his info on mapping etc i find it interesting wot these guys know about cars :razz::razz:
you will still need something for the boost control :)
and no the dump valve doesn't have to be recirculating for mild als :)
cheers Geof :)
N
new ralliart
cheers Geof :)
yeh actuly sponners u no ur shit wen it cums to a map...
i want everything that u just said for my ralliart but i also want the most out of it (whp) :):)
im in kent where do i go ?????
Sponners is firing on all 4 cylinders today by the looks of it:D:D:D
That statement can be read two ways........once reading it, Sponners will be looking either like this; :D or like this; :mad:
:D:D:D:D
Seriously though New RalliArt, please try to refrain from using that type of language here as it means that threads will need to be tidied up afterwards which is a laborious task to say the least.
Rules are in place for a reason buddy.
N
new ralliart
sorry :blush: :blush:
was typing in a rush lol
well i hope he likes it i just wanna go sumwhere where they know wat there doing so he defo knows hes stuff ( note the cleaner english lol )
i dont mind traveling a bit its just around here well the places iv been hav been like "well i ant done 1 of them b4 but ill giv it a go".... with sum 12 year old in the corner swinging a spanner!!!! errrr no thanks i wouldt let u touch me push bike mate lol
know wat i mean proper doughnuts lol
so if hes up for the challenge or knows sum1 around here thats as clued up as he is then by all means giv it a crack lol:):)
jackofq340
does any one know of somewhere near noeth wales that will do the ecuflash remap for me? also what does a boost controller do? is it needed?
where by in north wales are you mate? might be able to help you out :)
Hi mate, if you pm me some contact details and a few details of your car I'll get in touch with a guy in Kent that'll do you a top notch job for you :)
i know someone in mid wales who knows loads about mapping but im not sure if he actually maps or is he just waiting for a lead for his computer :razz::razz::razz:
yhpm
