Looking good lee,do a wire tuck if you get a chance to clean up the bay nice I'm doing mine end of this year
I'd love too but just where do you put it all lol
I have done some re routing and battery is now going in the boot
Coming along nicely mate.
Well as promised my gearbox was ready today at about 1:00 so picked it up.
Had a few issues lining the clutch up but got there in the end
Engine and box back in and most the wiring sorted. Just need to get a couple new gaskets for oil return pipe off the turbo and fit the rad, cooler and pipework
thats good going to get the box on a sunday![]()
must have had a busy afternoon to get that all back in
Andy
Your cars looking awesome man, shows you put sweat and blood into it, out of interest, im doing the cam belt ect on mine soon and its the first time ive done a belt on one of these engines, is there anything I need yo be wary of?
Ive heard the balance belt can be a bit of a nightmare but that was from a scooby tuner
just make sure when you set everything up at tdc mark the balance belt sprockets with paint. saves any guess work ect, aparantly timing marks arnt always acurate. cambelt timing marks are all spot on,
Yeah I normally use tipex and thats exactly what i would do, I just got warned that it can be thrown out of alignment regardless of where it was marked, but like I say, the guy I was talking to specalised in scoobies and skylines and even admitted to me that he'd only ever done one evo belt, which he done wrong and had to redo! :razz:
Thanks mate but all my hard work is based in the fact I can't afford to pay someone to do it all so over the years I've just done everything myself. I have all tools and space to do it so why pay someone else anyway![]()
Cambelt is a fiddly job which as you'd imagine requires work from the top and the bottom at the same time and right where the chassis leg is as well.
Its a pig to do in situe and at times requires 2 pairs of hands so don't try to do it alone.
Taking the plugs out makes rotating the engine a lot easier and you'll need to rotate it all several times till everything lines up. Once you done that there is a bolt in the block next to the downpipe. Just take it out and poke a screw driver in. If it doesn't go in then rotate again. You can rotate a little and try poke it in again just to see the difference. If it goes in then the balance shaft is where it needs to be.
Order the tensioner tools off camskill. They will make the job easier.
There is an auto tensioner which will need pinning with either a drill bit or Allen key, do this before releasing the tension off the belt. When you hit belt back on, wind tensioner round till the pin goes slack. Job done !
My first one barring in mind I'm just a Sunday mechanic with no training took me 12 hrs just plodding along on my own, with a little help with the fiddly bits.
Nice work pal, looking forward to those pics![]()
You may be waiting some time. Gonna leave it under wraps till action day at Combe![]()
