j14ymy
1.6 is safe with a remap to suit.
If you have already changed to a tubular manifold and bigger intercooler then I wouldn't do anything else till you've had fueling checked atleast.
Those 2 parts are major in terms of afr so get it checked....
thanks for th advise m8.. go see bout getting it mapped to b safe
best thing you could do
dont forget when your getting her mapped that you can also have mild anti lag(pops and bangs) and launch control enabled on your car.![]()
when changing my manafold i had to block the egr valve . been told i need that for the anti lagis this true ? ..... anti lag ia awsome
lol
not 100% sure of that i thought it worked through the sas pipes best ask whoever is going to map her for you for your options
It's a SAS pipe attaching to the top of the exhaust manifold. Not an EGR system.
Secondary air system - Exhaust gas recirculation
It is better to have it fitted but not essential. Antilag is negative timing on the map. The SAS system pushes more air into the exhaust system for better antilag.....
