evo 6 boost
1.6 is safe with a remap to suit.
If you have already changed to a tubular manifold and bigger intercooler then I wouldn't do anything else till you've had fueling checked atleast.
Those 2 parts are major in terms of afr so get it checked....
j14ymy
j14ymy
thanks for th advise m8 :) .. go see bout getting it mapped to b safe :)
evoaps
evoaps
best thing you could do :)
dont forget when your getting her mapped that you can also have mild anti lag(pops and bangs) and launch control enabled on your car. :D
j14ymy
j14ymy
when changing my manafold i had to block the egr valve . been told i need that for the anti lag :( is this true ? ..... anti lag ia awsome :D lol
evoaps
evoaps
not 100% sure of that i thought it worked through the sas pipes best ask whoever is going to map her for you for your options
It's a SAS pipe attaching to the top of the exhaust manifold. Not an EGR system.
Secondary air system - Exhaust gas recirculation
It is better to have it fitted but not essential. Antilag is negative timing on the map. The SAS system pushes more air into the exhaust system for better antilag.....
j14ymy
j14ymy
what is the sas pipe and were is it located ? cheers m8
