- Moray, 57N
:wtf::hm:
There's only real package to go for and that's the current DFV.
:wtf::hm:
Onlins may be a bit over kill but like what has been said, if there's no budget then go for them. They are supposed to be brilliant with full adjustability of the dampers (rebound etc) you'll be able to get them set up really well to handle most surfaces.
BC's only adjust stiffness both ways, a basic set up. But they are good and IV run them round nurburgring and track days with no issues, my friend is in the same boat too with his car and they've done fine.
What tyres are you running?
Have you got Rear ARB yet? (Whiteline)
Polybushes?
Fully braced?
such a hard thing to judge with all of the crap you read on here and MLR about aftermarket suspension and its the problem is that everybody listens, i sell BC, HSD, Ohlins, Sachs an dhave also owned and tracked all of the above suspension, including teins so i have nothing to gain from anything
Lower end of the market under £1000
BC + HSD - both bottom end of the market, price wise, very good for what you pay, both have had issues and because of that people who will tel you there pants, they tend to develop knocking in a small amount of cases which is simply down to the build quality control, most if not all get replaced FOC _ what i would say is the big difference between thee and high end stuff is the road manners, they are a lot stiffer than standard and an experience evo driver would noting there a bit lacking in feel. 1000's of folk using them though and very few experienced issues, if you fast road use there an amazingly great buy
MID £1500 - £2300
Ohlins/Sachs/KW
some extremely good suspension about here, most people only think that there are Ohlins in this bracket and lots of people who are "sponsored" spouting off about how good they are (naturally),then lots of folk taking that as fact. they are amazing but then you have to consider KW and Sachs, which is what i use. the thing you notice with suspension like this is that the road manners when not on the track is most often better than standard suspension, put it on the track though and it simply comes to life and offers so much grip. all of this range is nice and simply to use
High £3000+
Nitron - AST - Ohlins - JRZ - proflex
a set of nitrons for example would set you back £4000+ will normally be 3 way and a seriously good set up, in fact you wont get much better. for the average person though there simply far to complex to use effectively. i ran a set of AST 3 way suspension on my old evo 9 and took them off within 3 month, i just couldn't get them to work properly and realised i was out of my depth
personally i would say that each bracket of suspension are al as good/bad as each other, nothing between BC/HSD or Ohlins/Sachs apart from pricelots to be saved though. best thing would be to get out in a car with some on and see what you think. if your ever at a sprint or track day feel free to have a gander out in my sprint car, you would be stunned
I got bc's br because they were cheap and better than stock suspension.
Personally not that impressed with them, you get what you pay for with things. Very basic dampener, with original rear mounts they knock. That's just my opinion on them, there are better options.
Dan i am currently running these kumho's!
TBH Dan for the money they are a very good tyre with plenty of grip!
Currently running Standard damper's with Tein Springs with 3 point brace at the front and 2 point brace at the rear and standard ARB's and bush's!:sad:
Matt would you change these now then for something else or are you happy for what you get for the price you have paid and plan on keeping them fitted to our car?![]()
I would personally change them, they are an improvement over stock suspension and tein springs mind. Won't be any time soon so will have some chassic upgrades on first. Interested to see what difference whiteline roll bars will make to the car. Think polybushes, bump steer kit then see how the car handles. Maybe worth just running heavier springs to see if they make any improvements, would allow for more tweaking of the preload as it runs the rebound as well (feature I dislike, rather individual control)
Martins price for Sach's seems good.
Not a bad tyre those khumos![]()
Martin this is the reply i was wanting to achiveWhat are your currently running on your car now? I don't really use my car much so it will be more likey once a week if am lucky(more like once a month) and mainly want a nice handling fast road car which will perform well on the track!
im running ZF Sachs Race Engineering on mine and they are the best i have had by a long way, been in the top 3 of all of the sprints i have competed in since fitting themwas introduced to them through EvoTune when i was took out in there evo 9. i alays found the AST 3 ways, Ten Monos etc to stiff and skittish (even on the lowest settings). the biggest thing for me is a i have never changed or adjusted the setting since fitting them over a year ago, there just that well balanced
also the major thing that folk cock up on and fail to do properly is get the suspension set up properly and a good set up geomentry, the right camber and toe is vital to get the best out of them, im sure CPP will support you with this
Couldn't be more true! Should have seen the state of the geo on my mates Impreza when we just whacked them on, all over the place! Until he took it to a proper garage with all the set up equipment![]()
