Safe boost..? evo 8 260
So I can increase my boost safely by 20% can I ? :)
That's half a bar for me and I'm sure my turbo would shite itself as well as that me engine would probably be detting its tits off :shock:
Sorry Craig mate, disagree !
Evo-R
Well then guys. thanks.. I'll stick at 1 bar for now =)
Your car is far from standard lee work out 20% of your standard boost and tell me it's unreasonable
Evo-R
Where are you based? No point changing the boost until its mapped then you can run 1.8 bar all day long
Live In sweden =)..
What Is needed to map Evo 8..
Software..? hardware??
Bristol
to do it yourself you'll need
EvoScan, $25
Ecuflash free
AFR gauge ~£135 need one with a PC interface
det cans but you can use the standard knock sensor also
lots of reading on how to map a car and take things easy when tweaking make small adjustments at a time then test, test, test then make an adjustment again etc
Just to add 20% on stock e6 ralliart is 1.8 bar
How did you manage to work that out? :s are the roughly 1.5 bar standard?? No
Take the whole boost pressure for example 1.2 devide by 100 and times by 20 = 1.344 and that's safe to run
So a standard e6 ralliart is 1.5bar that's what I'm asking as I don't know
