invisible
- Nottingham
You may have seen from my other post that my car is currently in being looked at as the Clifford BlackJax5 decided to play up and prevent me from starting it. I'm now having this taken out (was just plain annoying anyway!)
While in I asked them to do a full inspection as was concerned about a few things.
Needless to say, apart from the gearbox crunching which I already knew. The following problems also confirmed;
- Turbo has an air leak and whistling, I thought as much
- Manifold cracked and gasket blowing, knew this anyway as still not fitted the replacement I have
I think my turbo is the weaker magnesium wheel one (9GT) so not surprised and have decided probably best to replace rather than get fixed.
I am considering the TT S209 as its a hybrid strengthened turbo as a direct bolt on as dont want to go too mad with the upgrade but at same time know it will stand the test of time.
Am also considering a rod conversion just for my own sanity. The Rod Coversion consists of :- Machine std Pistons, H Beam Rods, Rework Cylinder head, Cosworth steel head gasket, ARP head studs, Engine gasket set, Mitsubishi liquid gasket, Mitsubishi timing belt, Mitsubishi Balancer shaft belt, Mitsubishi oil filter, Millers 10w/60 eng oil,Antifreeze and labour.
As a general question (other than induction kit, walbro, exhaust, boost controller and remap) what would be good practice to upgrade too
I don't necessarily want to incure more cost but didnt want the other OEM components to go 'pop' after all that work has been done if they can't stand up to the new upgrades?
Any thoughts welcome.
Just off to chat with my bank manager!:disgusted:
