Oil in catch can?
Steveyb_evo3
Steveyb_evo3
Stevenage
How much would u expect on high boost in say a 5 min all out run?
Steveyb_evo3
Steveyb_evo3
Stevenage
I have about 3 mm in the bottom of the can u think this is ok?
I just get what looks like soup I'm mine. Mixture of oil vapour and condensation
But even then its bugger all
Shouldn't see anything after that, its daily driving that does it. Should take months to fill even if used daily.
That sounds a lot, the can run to both breathers?
Steveyb_evo3
Steveyb_evo3
Stevenage
Yeah both breathers
Daily driving there is nothing
On full boost giving it abuse ( on my private track ofcourse) it put a little in but I have since hammered the shit out of it again and it's not filled anymore so I have no idea
Was going to say maybe the pcv valve is gone letter oil come out. They do say you should run the pipe up slightly to reduce the about collecting.
Strange if its not doing it now.
Steveyb_evo3
Steveyb_evo3
Stevenage
Pcv has been taken out
The pipe goes up a bit now but had a hammering again and tiny amount more so it ain't a great deal
I'm gonna do a leak down test and just see where it's coming from
Know you can take it the pcv valve out when running a catch can, left mine in.
Sounds like its not much, may well be something wrong. Not damaged the underside of the rocker cover? Isn't there a cover plate to reduce oil escaping thought the breathers
