B
bakes fq
- Bedfont Middlesex / near heathrow
What sort of bhp and ft torque should I see from fitting these cams to my 9 ...? Performance mods so far are 3 port, fuel pump,decat, and hks filter ... Cheers
I would say there too aggressive for your setup.
These are good cams but you have to change the spring s and retainers as well, good for top end power. Is recommend the keyword 264's great mid range torque and power
Yes m8 i got it mapped on the rd and I see what u mean : ( . So if I get it on the rollers and I'm not hitting The 400 mark , would it be safe to fit the cams and then get it mapped again ?i'm assuming that you've already had a remap? with those mods you've qall ready mentioned are you running about 410-420bhp and similar torque? the cams cams would probably see 20bhp 20lbft in the mid range (may be a bit more) but for the cost (as you'd have to pay for an adjustable cam pulley, fitting and remapping its probably not worth it as you'd be on the limits of the bottom end
Andy
potentially, what boost are you running now and who mapped it for you? would be worth speaking to them also
Rich at Rg Motersport mapped it , mite have to give him alittle call and see what he says as I can't remember the full boost I'm
Running at the mo : ( . That's for the advice : )
