When i took the coilys off i removed both front shocks and both front hubs just dropped and inner cv's came out of their socket....so i put it back in but since then it been knocking when turning, i think one of the bearing thing has came off and with it being driven on i can see it being fooked. And as for the box (5 speed).....well its making some horrible noises and its just had a gearbox oil change, its ok when the power is on fully or off but when you let go it makes a metalic sound, it does it when your just cruising mainly in higher gears (4th 5th)...it sounds to me like theres
