Marty.H
- Norwich
what is the actuators box at the right hand botom corner for and how does it work
It is to test the items IE activate them
Make sure you use the latest v2.8 it has 100's of less bugs in it. RsvRob, if v2.8 has a bug, let me know so that i can fix it for v2.9 which is about to be released.
Plugging this cable in should allow your dash lights to blink, and will ensure diagnostic mode.
when the cable is plugged in, does the dash lights flash consistently or does it flash with shorts and longs?
Ignore the red plug hanging out the side, that is where a white 12pin adapter used to be when the cable was sold, the owner must of lost it. the extension plug is only used for reflashing evo7/8/9 and you don't need to use it.
If you have an evo4 ecu, you should really be looking to upgrade the ecu to evo7 ecu, and flashing in some tephramods and ralliart roms, which are free.
