engine warning light
  • Thread starter martinthegooner
  • Start date
martinthegooner
martinthegooner
Maidstone,Kent
took the car out last night and all was good then a very brief loss of power and the engine warning light flashed on and off,is it safe to drive it to a garage to get it looked at and should i be worried?
martinthegooner
martinthegooner
Maidstone,Kent
no light went straight out and stayed out,i was speeding up but not hard.
Clarkie-boi
Clarkie-boi
Windsor/Cippenham - Berkshire.
Jus give it a quick check over, see that nothing's noticeably wrong in the engine bay, check ya oil level ok, take it down the garage and get a comp put on.......
martinthegooner
martinthegooner
Maidstone,Kent
ok mate thanks,going to check it over in a minute,fingers crossed.
Steveyb_evo3
Steveyb_evo3
Stevenage
If the car has been mapped its on a cross over on the map if u went a little harder on the throttle it would just go past it
martinthegooner
martinthegooner
Maidstone,Kent
right just checked all levels and they are fine,car starts normally with no lights on,took her for a spin and let her warm up then put my foot down but not too hard and all was normal,im confused.
Was it turbo stall ?
Sometimes when putting foot down in a high gear on a hill you can get compressor stall which is just at the point it's building boost quicker then the car can increase engine speed so the boost control let's the boost go then builds it again :)
martinthegooner
martinthegooner
Maidstone,Kent
thanks everyone,im taking it to see a mate who has a dianostic machine so will see what comes up.
Jonny IX
Jonny IX
Group Buy Organiser
Shropshire
did you disconnect the battery after the engine light came up ?
If you didnt then , one cause ould be a knock sensor mapped in to the engine light ...some geeks put it on when there mapping...stevey's got it on his III (I think)
Steveyb_evo3
Steveyb_evo3
Stevenage
Yep :)
martinthegooner
martinthegooner
Maidstone,Kent
i havnt no,it did come on then went straight off again and a quick loss of power 3 times on drive to garage,seemed to coincide with having the air con on or could have been a coincedence?if i disconnect the battery wouldnt that cause me probs with the immobiliser?
Jonny IX
Jonny IX
Group Buy Organiser
Shropshire
no the immobiliser SHOULD be fine in effect...which immobiliser do you have ?
does it have a in-car fob (a little stick you press in to a plug on car) or does it have a key fob job..if it has both it will be fine ...if its a cobra alarm then re-programming is P.O.P anyways PM me for details on reprogramming if you need it !
