martinthegooner
took the car out last night and all was good then a very brief loss of power and the engine warning light flashed on and off,is it safe to drive it to a garage to get it looked at and should i be worried?
Jus give it a quick check over, see that nothing's noticeably wrong in the engine bay, check ya oil level ok, take it down the garage and get a comp put on.......
Normally if it's something bad that light will stay on, but it's always good to see why it's come on..... Best be safe then sorry
If the car has been mapped its on a cross over on the map if u went a little harder on the throttle it would just go past it
did you disconnect the battery after the engine light came up ?
If you didnt then , one cause ould be a knock sensor mapped in to the engine light ...some geeks put it on when there mapping...stevey's got it on his III (I think)
