Yep, failing that there is a bolt in the side if the block that doesn't appear to do anything. It's in the turbo area it is just a bolt that doesn't hold anything on.
Remove it an insert a screw driver in the hole and if it only goes in a few mill then the balance shaft is wrong. Rotate shaft until screwdriver goes in a couple inches.
