Abs on evo 4 help
Matturbo
I disconnected battery for 5 min then light was off drove and it came on that right?? I mean to reset??
m7gsr
That should normally do it but may have to reset with diagnostic tool. Someone will be able to confirm shortly
Dave Brennun
Dave Brennun
It might be better if ya take the sensor out and then reset, then put the sensor in and reset again!
did you check the abs ring on the drive shaft? (cant remember the correct name for it) - pretty sure this would throw the same code if its damaged.
dissconecting the battery lead will reset fault codes for you.
Dave Brennun
Dave Brennun
He done that pal but still no joy from what I read. Ya got a point there on the ring though!
yeah, so its pointing at something other than the sensor or hes fitted another duff sensor
