Slow Electric Window Evo 8
Jas Lad
Guys my drivers side window is slow as hell when coming back up, seems to speed up nearer the final few inchs, any ideas?
Leigh_EvoIX
Leigh_EvoIX
Check the rubber runner is not catching and hindering the motor.
Dirty window liner, clean it up and pop a lil grease in the runner if doesn't fix it a new motor might be in order
Jas Lad
Cheers, when you say window liner do you mean the regulator bits that go way inside the door?
Na I mean the seal that the window runs in, they can get clogged with dirt sometimes
Leigh_EvoIX
Leigh_EvoIX
It does go down behind the door card too. Sometimes they come loose and get twisted.
micevo
Fairy liquid is your friend... squirt a little around the rubber inside an out
mrt72
mrt72
silicone dash cleaner is ace for them, just spray it in the groove and job done.
