Flywheel grinding starter after disengaging.
SaulHudson
I've been having this problem for awhile after my VI swap into IV. First, I was getting back feed to the starter and it was staying engaged( I think this is still true but it may not have been a problem).
My starter will disengage but the fly grind the starter wheel at the static position. I know this because when I do a compression with wrench or push the car I can hear it grinding. When it starts the starter always grinds. I bench tested it and it disengages fine. I have been using the IV stater( 2mo old rebuilt) with the flywheel that was on the IV engine(unknown evo model). I got a VI starter in and tried it out, same exact thing. I will get pics up but the starter wheel has maybe 1/8th in ground out of it on every tooth where the flywheel has been spinning. Its as if the starter mounts too close to flywheel but I am using the same combination as I was on IV engine. The flywheel can't possibly sit closer on the 6 engine than the 4....
Any ideas?
Might b a sticky solenoid don't think it's a common fault but it can happen I would grab another if I was you before it screws the flywheel and becomes a gearbox off job pull the starter off crank the car by hand and look through the starter hole and check the teeth haven't worn or rounded off
SaulHudson
I said in my post that I got a vi starter and tried it out, I noted the same exact results. The starter does disengage, I bench tested them. They grind when the starter is disengage the wheel is too close to flywheel. It also grinds when I turn the car by hand or push the car.
Sorry fella I had just woke up when I replied.
Well if they too close is it the right flywheel? Cos they shouldn't be
sure its not the small inspection plate at the bottom dented in and touching the flywheel?
SaulHudson
All I can say is, I use the same flywheel and starter on my IV engine and it work fine none of this nonsense. I think really the only thing is could be is with mounting of flywheel. The flywheel may be warped, or torqued incorrectly and it is wobbling?
Possible, pull apart and have a lookie. It's a strange one I know that much
