as i recently purchased a new S90 70mm throttle body i thought that as it has a much larger internal diameter then the inlet mani should be opened up to match.
only issue with doing this is that there isnt quite enough metal all the way around the port so certain areas need to be built up first and as there are a couple areas where once the port has been enlarged the metal will be very very thin so it was decided welding would be required around the whole circumfrence of the port.
time taken by my local race engine specialist to do the welding and the porting 5hrs
time taken by myself to grind back any excess weld and sand and smooth down to a more factory finish (external only) 4hrs
you may remember i painted my inlet white, we its been in the acid to remove it all so as not to cause problems when welding but will be powder coated back to white again this week as will my discollureing rocker cover.
some before and after shots
And the finished product
