where can i get coil packs from
evo arm's m7960
evo arm's m7960
what Toyota are the coils taken from.... model i.e. yaris 1.4?? thanks
yaris 1.0 1.3 . p /num 90080-19021 or 90919-02240 are the best to go for
but you can use p/mun 90080-19019 or 90919-02239 but the wiring plugs point up so you cant use the plug cover .
the ones in the picture are 90080-19021 if i remember right :O)
remember if you buy coils you need to buy the wiring plugs that plug in to them to
redevo
Isle of Wight
on the MLR a topic there shows a guy using denso 90919-02229, are these ok to use also?
Smokey
uk
Where is the best place to buy the connectors? i take it you need 2?
Thank you
evo arm's m7960
evo arm's m7960
Thank you
thats the hard part finding some one willing to sell them with the coils or split the loom :O(
ive never tryed that hard to find them on there own but am sure some one must sell them as a repair kit ???
Smokey
uk
ive never tryed to find them on there own but am sure some one must sell them as a repair kit ???
So you got them the same time you got the coils? :)
D
Dave Spalding
Looking for a template for the mounting plate for this. If anyone has one can you post up measurements. Or even post to me and I'll pay postage.
evo arm's m7960
evo arm's m7960
f,a,o dave :O)
here you go dave hope it helps . this is not to scale
im not that good at tech drawings sorry :O)
all in mm and all measurments from left and top down . all holes are 8mm and coil holes are 26mm minimum :O)
coils are set 2 up and 2 down but its up to you how you mount them .
make this in card first to be sure that your happy with the lay out befor making it in alloy
this is from my template for a evo 4-6 the later evo's i believe you have to trim the corners to make it fit
cheers :O)
P
Putty
Hi Paul
Cheers for the template i've been thinking about doing this on mine.
Just one thing on the 3 measurement from top to bottom of 56mm the one on the far right doesnt have a measurement from the left any chance of that to help?
Unless you wont to make me one up and i'll send Will over to pick it up and drop some beer off lol.
evo arm's m7960
evo arm's m7960
oops sorry my bad :O)
296mm
this is just how i did it its up to you if you use all 4 mount points or have all your coils the same way round and or hide the wires under the plate . failing that i have a set for sale in the sale section :O)
you should end up with this ,
ps, make it out of card firsts :O)
