Wheel baring ??
rich_f
rich_f
Hi guys
Would you be kind enough to describe the feeling of a wheel bearing on its way out or completely gone?
Tried giving the wheel a wiggle from 12 o'clock and 6 o'clock give it a turn and try again can't feel any play but convinced I got a problem.
Rich
rich_f
rich_f
Ok kl
Well next question lol
There is vibration that I can feel while driving can feel it through the floor and pedals but it comes and goes when turning corners
Any ideas ???
does it just happen on a full lock and does it continue to do it untill you straighten the steering again ?
rich_f
rich_f
I can feel it when driving straight and when I go in to the corners it goes
a rattling knock when driving over very very slight bumps and dips ?
chrishfq300
chrishfq300
Wheel bearings can be rough an noisy without any evidence of play top to bottom, you will feel the vibration through the car but more so the persistent grumbling noise as the wheel rotates, the faster you go the louder it will be.
couldnt agree more chris. anti roll bar bushes i reckon :)
W
waynev
sounds like it could be a wheel bearing. when the steering is turned the weight shifting from side to side can make the noise come ang go....there dont need to be play in a bearing for it to be fooked
rich_f
rich_f
I have heard a bit of noise and yer it gets louder the faster u go.
rich_f
rich_f
Think I may take it out and have a feel of the bearing see if it's running smooth or rough
I'll go with wheel bearing, its one of those funny ones that can cone and go depending on how serious Yh pull apart and inspect best way
