SaulHudson
Do I need a better intercooler than stock 4 FMIC to run an evo 8 turbo on a 4?
To be honest mate. The 4 engine won't take much more boost than your running already. Its none to suffer from ringland failure and crank walk. Its recommendedby many to only run 1.2/1.3 bar boost
Amd pushing 350bhp on a 4 engine is unlikely to![]()
There are always exceptionsi beg to differ on that one, mines 350 and has been boosting at 1.5 bar and over all day long,![]()
I know I'm not on track, but trust me I'm no driving miss daisy, Lol
I am not putting a evo 8 turbo on to run more psi. the 8 and 9 turbos have same housing as the rest put compress more than the lower turbos. I will still run 20 lbs with the 8 turbo but that 20 lbs is more boost than 20 lbs from a 4 turbo. The evo 4 turbo can boost well over 20 lbs, my internals can't, so putting a same size turbo in and boosting the same will give me more boost if that makes sense to you.
Mine was fine too till I started using me antilag for launch... Lasted a year tho
Now I've got low compression in cylinder 4lol
whats your plan now then?
new engine or rebuild that one,
ive 2 forged engines hereone in car which is comin out and maybe forsale only done track miles really running 1.9/2.1 bar, could maybe do with a new set of rings and a hone, but runs very strong, been in about 3 years,
its 0.5 bored, 5 block, balance shafts removed manly pistons and rings all ARP head studs, bottom end built and machined by wards of rugby(drag engine specilist) MR head gasket, head got piper uprated valve springs would come with E7 cams as the ones init i need, probally would want around the 2k mark for it,
if my plans change then other would be around 2.5k E7 block scat rods and wisco pistons iirc but would confirm first also balance shafts removed, standard size bores done 2k since rebuild,
but nothing till new year as gotta see what were doing maybe changeing from evos to clios if so then everything will be sold...
thats ok wasnt looking to do any think till next year my self :O) i have hit the limit of my e4 at 417bhp so gotta go forge .will keep a eye out for your for sale post and see what my funds are doing at the time :O)
cheers paul
