After An Upgrade Ecu??? Or Want To Get Your Existing One Mapped???
jamie@evotune
Co. Durham
can you put a evo-9 ecu into a evo6 ??
It can be done but only worth it if you are going to be running a mivec head if not then you end up with cel lights on due to the lack of mivec sensors
Mid Wales
as Jamies said, can be done but a lot of work and only worth it if you want to run mivec.
7's and 8's dont have mivec
ASC7
ASC7
Southampton
E7 and E8 260 ecu's are a easy swap but not really worth it now as the E6 ecu is just as good
The only reason i bring up putting a evo 7 or 8 in my 6, is so that it has OBDII software...at least that's what i think they are compliant with..
was then looking to plug into this a scangauge/computer gizmo...
dic
dic
shropshire
took my car for a map recently.
and the mapper could'nt read the mph.
said the prob was delimiter wired near the speedo and not to the gearbox was the prob.
so went home and asked my mechanic where he had put it, and he said the gearbox???
any ideas why it is not reading the speed???
i have a iv with with a vi tommi mak ecu.
9
98duffa
hi all. i have an evo7 import with dump valve, decat and exhaust, air filter, walbro fuel pump and soon to have a pressure valve and remap. if i was to have my valve and remap dun then in the future fit an exhaust manifold would this screw anything up or wouldnt it really matter before or after the remap. thanks all
C
chrisevo4
ilkeston
hi all i have a evo 4 with ....
evo 6 ecu
evo 6 injectors
up rated fuel pump
boost controller
hks filter
hks system
decat
down pipe
up rated manafold
up rated clutch and flywheel
im looking for some 1 to map my car in ilkeston or nearby.. any idea of what sort of power i can get its only a sun toy so u can map it within a inch of its life pmsl and i would like pops and bangs ?? antilag ?
EVOpower
hi mate, i have an evo 5 with an evo 8 engine. desperately need it remapped. it has standard evo 5 ecu, walbro fuel pump, greddy profec b spec 2 controller and breathing mods....can u help???
jamie@evotune
Co. Durham
Who is that question for ?
H
Hughandjenny
Hi im in York and have bought a 6 with forged piston walbro pump, gizzmo boost control etc etc. It has been mapped to 410 bhp at 1.7 bar of boost. In next few months would like it to be checked over that it is running ok. how much do you charge if I came to you for a map check.
Thanks
evoaps
evoaps
Wexford Ireland
Thanks
The guy that started this thread is not an active member anymore
jamie@evotune
Co. Durham
Thanks
We are in County Durham so not too far from York I could check the car for you if you wanted, we have our own Dyno aswell.
H
Hughandjenny
Thats great will be in touch within next couple of months
