jamie@evotune
can you put a evo-9 ecu into a evo6 ??
It can be done but only worth it if you are going to be running a mivec head if not then you end up with cel lights on due to the lack of mivec sensors
i take it, that would also apply to the 7 & 8 ecu's
E7 and E8 260 ecu's are a easy swap but not really worth it now as the E6 ecu is just as good
hi mate, i have an evo 5 with an evo 8 engine. desperately need it remapped. it has standard evo 5 ecu, walbro fuel pump, greddy profec b spec 2 controller and breathing mods....can u help???
Hi im in York and have bought a 6 with forged piston walbro pump, gizzmo boost control etc etc. It has been mapped to 410 bhp at 1.7 bar of boost. In next few months would like it to be checked over that it is running ok. how much do you charge if I came to you for a map check.
Thanks
Thanks
Thats great will be in touch within next couple of months
