best or worst mod so far ?? :O)
evo arm's m7960
evo arm's m7960
hi ever on the quest to improve a already well made car , i was wondering what you all would consider your best or worst mod ??
from a little thing like removing the clutch slave cylinder reducer " better gear change , less slip with more power .
fitting bearing in the gear linkage ends " to replace the worn out rubber one's .
to stroking the block , what really work on the road ..
i would have to say that the biggest improvement to my car was reducing under bonnet temps" got to over 90c when the rad fan cut in .
used fan shroud keeping heat off the intake pipe to the turbo .
heat wrap the manifold .
fitting hondata inlet gasket .yes they work .
and a small stat controlled fan to cool the injector rail and inlet manifold in traffic jam .inlet temps over 60c .
any one sat on the m25 will know what i mean :O)
and a rubber strip down from the bonnet vent to the head to funnel the heat out .
worst .
fitting a 6 puck stage 3 clutch and flywheel and not fitting uprated engine and diff mounts first . ooops :O(
Hereford
My best mod is my first mod, my carbon fiber eye brows :awesome:
My worst was a hks dumpvalve
Matt-evo-v
Matt-evo-v
Aberdeenshire
Worst mod:
Excedy twin plate. Over kill for what I needed in a clutch and a nightmare driving round a city :mad:
gooner8
gooner8
berkshire
best mod boost controller worst mod new air filter coz I've had to turn the boost down lol :)
evo arm's m7960
evo arm's m7960
it alway suprises me how often when you make one small change " no matter how small " the resulting side effects can be so large , resulting in poor drivability or loss of power to the other extreme of great power gains and a greater driving experience .
how one mod / change can effect another parts role ......".strange kind of witch craft happens " jc"
gooner8
gooner8
berkshire
yeah and it need's a map badly! Never had prob before tho with dump valve some people do. Ecu injector's and so on. But the air filter made it boost cut! Do love the sound and the new turbo chatter! :)
evo arm's m7960
evo arm's m7960
im running a big kn filter, 4" inlet to the turbo no air flow meter .
i got loads of chatter after i changed the lower boost pipe for a bigger bore "was letting the boost return back to the turbo "
solved this by reducing the spring pressure in the dv . wasn't a problem with my old tommy mak turbo 15gk2 but was with my new tomie m7960 20g . go figure
as for a remap i got some cam's to fit and that will bu ger up my map :O(
J3ayy
J3ayy
Malton, North Yorkshire
My best mod is my Damd carbon side & rear skirt extensions :) Worst mod a MLR sticker
Moray, 57N
FULL polybush kit. Makes the car noisy as hell but my GOD does it handle better :D
Steveyb_evo3
Steveyb_evo3
Stevenage
Best
Cusco zero2's Awsome difference
Gear linkage on gear box amazing change
hks twin plate
Worse
Apexi intake way to hot intake temps now
17" alloys so slow putting my 15's back on
My worst mod was probably painting my brembo calipers White. Yea they looked the nuts when I first done them but they didn't stay like it for long lol
Best mod now that's a tricky one cos after 3 years of modding I've lost track of what I done lol
I was quite chuffed with my home made mounting plate I cut and shaped to mount my water temp gauge and custom sensor location :)
gooner8
gooner8
berkshire
didn't no your car had leg's like that lee. No wonder you spend so much time in her.:whistling::whistling:
best is the cf look dash, worste is the air box mod, looks awful and regretted it ever since, so i cant wait to get a proper intake on it
well you would spend plenty of time when there is grass on the knee ;)
i take it your better off selling phones that playing the craftsman lol :)
Well the cf dash looks good the air box mod my brother found out about and egged on and that went Tits up lol,
