overfueling and missfire
evo lee
evo lee
dewsbury west yokshire
:cry:everytime i floor it it backfiers and loses power and then there is a stong smell of fuel but its not doing it all the time .and allso it is drinking fuel like mad i did 160 miles at 70 to 80 mph and used a full tank just got the car so dont know mutch about it all i know it has not been remaped its an evo 4 with a e5 engine in gunner try my mates evo 5 ecu to see if that solves it .
i need all the help i can get with this thanks :cry:
Evo 5 engine with std 4 ecu will mean you have the bigger injectors (560 red top) than the ecu is set up for from the 4 injectors (510 yellow top). Thats probably the reason your drinking fuel. But 160miles to the tank is prob avg for most people with an evo lol
Change the plugs for some BPR8ES with a 0.55mm gap may solve your missfire. Check the plugs anyway for overfuelling signs. If changing the plugs doesn't help then it may be a coil pack has broken down. Find the missfire cylinder and change the coil pack with another to see if it moves.
evo lee
evo lee
right just checked engine number and its come up has a e4 and not e5 :disgusted: and has red injectors so i need some yellow ones then :confused:
No just get a 5 or 6 ecu. There plug and play and you can then get it remapped aswell :D
The 5/6 ecu is already setup to run the bigger (560 red top) injectors. Check the ecu (located in the passenger footwell, behind glove box, bolted to side panel) If its a metal case its std 4 ecu. If its black case then you already have a 5/6 ecu and the missfire is your plugs or coil packs
evo lee
evo lee
got a e5 ecu and its solved everything and it seems faster, all happy again .
and in a few weeks i will have got hold of a ralliart ecu .big thanks to rob
andyevo5
andyevo5
hi lee how's it going, evo 4 engines start with a t,
EVO III/IV: TB, TE, TF, TG, TH, TJ, TK, TL, TM, TN, TR, TS
and evo 5 engines are here,
EVO V: XG, XH, XJ, XK, XL, XM, XN, XO, XP, XQ, XR, XS, XU
your engine is a 4g63 xj****, :D
now get some money spent,
Marty.H
Norwich
Sorry to hijack a thread but where is the engine number located on the block cheers :D
andyevo5
andyevo5
if your looking at the engine from the front of your car it's to the lefthand side just under the manifold, and behind the power steering pump,
evoaps
evoaps
Wexford Ireland
here u may need a flash light to see it properly it stick out from the block a bit
