loud tapping noise under load and lost power
Chris @ auto torque? Hope you get this sorted mate! Was it you who had the knock on the front right at the pod.
na that was chris the same chris who is lookin at my car, he is on here as chrisfq300,
i spoke to him earlier he has ordered new oil, filter, plugs and is planning on flushing the engine through and monitoring it for a couple of days and go from there
gooner8
gooner8
berkshire
ah right. Sorry was just trying to work out if we'd mean't or not, putting a face to the name and all that! So Chris the fella who parked next to cossie has got your car? I didn't know he was a mechanic, hope you get this sorted mate. Hopefully its nothing to bad? :)
yh he has got a family bussiness garage and luckily enough we have the exact same car. yh we met but i didnt have my car that day my brake pads needed replacing and i didnt get that done til the following day. i had the blue jacket on with my hood up all day i felt like death warmed up lol
gooner8
gooner8
berkshire
that's cool let's hope he can find out the prob. He had an auto torque sun strip so i just thought he went there. :)
Yea I know who you mean I was just taking the pee cos he hasn't been on here for so long :wtf::meh:
Lol yh, he jus all of a sudden stopped on here, sayin that fi has been a lil quiet too recently
He's been working all the hours I think tbh.
He has flushed out my engine done a service and is pretty certain that its my tappets. I'm gonna get the car back early next week and take it easy for a bit getting the new oil round the engine and hope the ticking clears up. We have also found out that the car didn't have its cambelt done at 40k. So that needs doing asap so with a bit of luck I can sort that out early next month. Jus gotta take it very easy last thing I need is for that to let go
picked the car up tonight and car is still the same
loud tapping/ticking around 3k and loss of power. almost feels like when you leave maf unplugged. my brother is of the opinion that one of the tappets is sticking could this lose me power.
i have put the car back to standard and double checked all and all is connected so no boost leaks, gauge reads ok.
im lost with it now, i have sorned it off the road until i can work out my next move, im thinkin of taking the lash adjusters out and cleaning them up and see if that makes any difference.
if the maf was up the creak without a paddel would my managment light come on im guessing yes.
You need to get it to a specialist mate. We are just clutching at straws now. You say its boosting ok yes ?
Sometimes it boosts and most the time it don't . Who would be the best to take it to in that case
Jonny IX
Jonny IX
Group Buy Organiser
Shropshire
Craig,
dont want to be a scare monger here but have you had the sump off and looked for swarf or bits of big end !
Ive been looking at a few of these threads recently and it seems it is happening a fair bit recently.
Due to power loss and tapping id be more pointing (crying) towards big ends mate.
Get the sump off and check it it may just be the big end shell, but this would be the check id be doing as if it is big end then its a UCKIN expensive job (REBUILD). After the sump off check the lash adjusters.
Just remembered chris had your oil out and flushed, did he see anything in there ?
or more to the point was he looking for it ?
gooner8
gooner8
berkshire
try Chris @ auto torque, mark shead @ mad or ant @ indigo all on here. don't no who's near to you of the 3, but never heard a bad word about any of them. :) imo
mike evo iv
ellsmereport
hi i did say a few threads back about looking for swarff in your sump like jonny ix just mentioned. if you read my threads a few pages back what i said. it sound the same as what happend to mine the tapping nosie wasnt my tappet it was the piston hitting the head, coz there was very little oil the heat mealted my bearing and one sliped out of place and scored my crank.it was to badly scored to get reground. just take off your sump and caps and run your finger over where each bearing has been you might find its the second one from the left or the far right one. it worth a look. its somthing that you can do and will save you a bit of cash rather than take it to a garage and get charge just for looking at it and yhen you find you havent got the cash to fix it yet
Mid Wales
I assume timing marks were checked and ok?
did they carry out a compression/leak test?
visual inspection of the valve springs? one broken causing tapping and valve leaking???
W
waynev
beds
i listened to this when it was at the garage and it is the tappets. get some decent 3mm ones and that will sort it. chris at autotorque is the man for running problems but do the cambelt first just in case
