N
nettielikescars
My clutch pedal seems to be very high, is there any way of adjusting it?
The clutch isn't slipping at all.
How much higher is the pedal than the brake pedal??? how high is the biting point (half way, less than half way, 3/4.......)???
Which evo do you own?
Fill me in and i will get back to you today.
There is a bolt with a spring loader mechanism attached to it. It is located behind the clutch pedal quite high up in the bulk head (under the dash).
If memory serves correct.....I suggest that you get a 10mm socket on a baby ratchet and a torch and get turning matey!!!!
All the way until the pedal is where you want it. Check your clutch fluid to see that it is at the max level while your at it.
Let me know how you got on please.
Oh and take a moment of your time to reply to 2 of my threads entitle Me My Evo & I, Calling All Evo Owners.
