Viking Dave
Hi guys, bit of a strange one i guess.
When i bought my 8MR FQ320 it had, for some unknown reason, a square import style rear number plate fitted to it. First job once i'd bought the car was to replace it with a UK style rear plate...to fit the UK size plate aperture. I noticed when fitting it that the existing metal plate fitting bracket, i assume the original bracket as fitted to the 8 GSR prior to the FQ UK conversion process, actually sticks out past the face of the rear bumper plate aperture which means you cant stick the plate flush onto the rear bumper in the plate space. I ended up 'building out' either end of the plate with layers of foam adhesive tape so that the plate wasn't curved, and sat flat in the aperture. Anyway's, the plate has finally fallen off after 18months, so i wondered if there's a UK plate mounting bracket that screws into the existing metal bracket, that either holds the plate, or has a flat mounting plate allowing you to stick the UK plate to a flat surface. I'm sure i've noticed some kind of mounting plate 'lugs' in some pictures i've seen on other FQ cars in the past in pic's posted on here, but can't seem to find any examples when i searched, for this post? I want to stick the plate on as i really don't like the unsightly plastic screw heads sometimes used to fix plates.
Alternatively, if others have experienced the same issue when mounting rear number plates, how did you get over it ? I figure if i'm replacing the plate, i'll make this the last time and do it properly !!
Hope my rambling's make sense and many thanks for any help
