stevolution2010
- oldbury(WEST MIDLANDS)
hi just wanted to know is there anyway of adjusting the fanbelt on my car as its squeeling at low revs i dont think its the lower cam pulley wheel as i replaced it 3months ago
Tensioner is easy to change.
Remove offside front wheel.
Remove plastic cover to acces bottom pulley area
Using a half inch square drive ratchet insert it into half inch square socket on face of tensioner and rotate anti clockwise until you have released enough tension from the belt to pull it off the bottom pulley.
Then remove the 12 & 14mm bolts that secure the tensioner in place
Job done now reverse these steps to re-fit![]()
you could also post this in the how to section![]()
I should have put a fiver on that comment coming lol![]()
