right, ill have a go now
standard 9 and 8 mr internals will take upto around the 400/400 mark and will still be a nice responsive car and yea, youll prob leave the others trailing if you get it off the line right.
if you want more than that then indigo-gt can do you a forge drop in job which is rods and pistons head bolts and gasket etc then this will hive you a nice strong engine. youll also need a goos set of cams like kelford 272 and some adjustable pullys. 3k ish
then its turbo time, S205 is very good and uk made by turbo technics and faultless. £1400 then manifold 600 ish
or a gt3076 kit 3k ish includes manifold
intercooler, ams/aps etc 600 ish
rc 1000cc injectors 300 ish
twin plate clutch 1200 ish
3" down pipe, de cat, full exhaust 4-500 ish
air filter 90 ish
boost controler 2-500 ish the underlined parts would also be need to get to 400bhp
all these parts except the engine work are new costs and would still need to be fitted
