evo 8 mr fq340 help
simon999
yeah i am def sure it will out handle all of them and the cosworth is a serria so it rwd not 4wd which is good. what do u think it would do in a straight line against the others would i come last with 400/400
as did want to do some runs with the others up santa pod
South Wales
You wouldn't come last as you would be able to put the power down a lot better than 2wd cars;)
South Wales
ok mate do you know how much power is safe to put though a evo 9's engine
400 safely with standard internals I wouldn't go much beyond 400, there are some that go way past the sacred 400 but I brlieve the inevitable rod through the block scenario will arrive prematurely:cry::cry:
simon999
lol joker so to get to the 450-500 bhp mark i am looking at a forged engine or is there another way with out having a full build engine
South Wales
What you will need is a rod job which requires machining of the std pistons to accept floating pins, uprated rods, rod bolts etc. iirc Norris Designs offer this service.
simon999
thats good so do u think that will see me to the 500bhp safe to u think thats cost alot
right, ill have a go now :)
standard 9 and 8 mr internals will take upto around the 400/400 mark and will still be a nice responsive car and yea, youll prob leave the others trailing if you get it off the line right.
if you want more than that then indigo-gt can do you a forge drop in job which is rods and pistons head bolts and gasket etc then this will hive you a nice strong engine. youll also need a goos set of cams like kelford 272 and some adjustable pullys. 3k ish
then its turbo time, S205 is very good and uk made by turbo technics and faultless. £1400 then manifold 600 ish
or a gt3076 kit 3k ish includes manifold
intercooler, ams/aps etc 600 ish
rc 1000cc injectors 300 ish
twin plate clutch 1200 ish
3" down pipe, de cat, full exhaust 4-500 ish
air filter 90 ish
boost controler 2-500 ish
the underlined parts would also be need to get to 400bhp
all these parts except the engine work are new costs and would still need to be fitted
mark.
air filter 90 ish
i'll make a note of all that as i prob will get mine done next year chears lee lol
