transmission noise on my evo v
evoross
perth
;)Evening,new to mitsubishi evo's, had 4 imprezas previously and fancied a change,glad i have so far anyway!,anyway getting to point,my evo5 is making a grating/transmission noise when slowing down at slow speeds and in lower gears,ie in town, transmission is spot on when accelerating,gears lovely & smooth,noise appears to be coming from n/s front area,not sure if this is normal noise on these cars as i haven't driven one before,any ideas people would be appreciated,thanks Ross:D
F
frenchfried
Hi I have exactly the same on a VI but it sounds like drivers rear. Did you find out whats going on, I fear it could be the diff on mine.
Thanks
evoross
perth
transmission noise
;)yep,stripped down gearbox and transfer box,stripped diffs to check and eventually found it was the crown wheel on front diff that had a chippped tooth,just got to build it up now and replace clutch and thta should be it,,hopefuly!!
Thanks
