evoowner
ABS Light Can you help??
Hi Guys and Girls,
I'm new here, and have posted in the newbies.
Ok, this weekend, in the snow like most people, although the difference may well be, that I went and bumped the curb, with my Evo IV!! :blush:
This was about 10 MPH, yet still skuffed the 18'' alloy quite bad, also knock things out of line on the left rear, I've adjusted the arms to bring it back into line, although, this will go for a 4 wheel track next weekend.
Just wonder if there's and arm, that is the most likely to bend out of shape? Although, close inspection doesn't show anything bent, or twisted.
The main problem, is the ABS light is now on!!
None of the other lights stay on, just the ABS light.
There does seem to be the correct clearance between the ABS sensor and the sensor hub ring.
Also I've checked the connections, WD40'd them, but still the light shows.
Any Ideas chaps/Chapesses?
Cheers.
Hi Guys and Girls,
Cheers.
