evo 4 tyres
mellykp1
hi again everyone just wondered if its true that if i change any tyres that i have to change all 4 at once as i need to put 2 new tyres on my evo 4 can i change just the 2 or all 4 thanks
Nick
Nick
Superstar Admin
North Yorkshire
It is recommended you rotate tyres so they all get changed at the same time. So for non directional tyres, fronts do a big X (front offside to rear nearside etc) and then backs forward and directional tyres are front to back.
But im a rebel and do what the feck I want, which usually results in me changing tyres at random intervals. (Only caveat being my road car is fwd and the evo i play with gets new tyres every 40 miles or so...)
mellykp1
thanks for that i was told that if you didn't change all 4 at the same time it puts strain on the diff
Nick
Nick
Superstar Admin
North Yorkshire
Yeah bit of an urbun legend. It is said because if you have one end of tyres with a smaller diameter than the other end your not going to be rotating the shafts at quite the same speed.
But the amount of slip needed is so minute if a diff couldnt cope with that it would go bang and leave a trail of broken gears on every corner.
mista bushi
^^^^ what he said lol
However for MOT purposes you MUST have same size tyres on the same axle.
(i found out the hard way after being sold 2 different sized tyres without noticing on the R33)
Tom C
Tom C
Essex
I find the 2 front tyres wear-out quicker than the 2-rear, which I find weird as its a 4WD Car :confused:
mista bushi
yeah but the 2 fronts also steer therefore will wear down quicker.
