Massey - Logs
massey
massey
im so tempted to get mr cossie1 to map it and sort it at the rr day
Mid Wales
if your going to the rr day then get Russ (cossie1) to check it over and he'll advise if anything needs sorting.
Mid Wales
is it safe to drive for now?
yeah, should be ok mate.
I've set it in your ecu so that if the engine starts to det it will flash the check engine light for you so you know to back off.
....you should have seen the check engine light flash on a couple of occasions today whilst doing them logs if its working ok???
