Cut Wire
mikeyb1983
Hey all........me again:blush:
I was looking to wire in my fog lamp and realised there is a switch in the little coin pocket on the very right of the driverside, took it out and it has what appears to be household 2-core cable running from it. Traced it back and found it was TAPED, yes TAPED a wire in the back of the speedo cluster plug.
Here is a pic, it appears that it is a black and white cable about 5 pins down.......any ideas what it could be for would be a massive help!
DDS789
DDS789
Weird.
I'm finding a few oddly done wiring jobs in my car lately as I strip wires back from stuff I done use anymore.
Found gauge looms, vacuum pipe for a boost gauge, and loads of alarm wire from when that was fitted amazing what some places do and where they will shove excess wire.
Google a wiring diagram for the speedo and work out what the pins do. I'd imagine it's some form of illumination button on/off for gauges or something.
mikeyb1983
Yeah i know what you mean, think this may just be the start........uh oh!
I will do mate, cheers. I wonder if it has anything to do with my AYC light no coming on at all!?
mikeyb1983
Yeah bulb has been replaced as thought this might have been the case.......but still not working........found wiring diagrams but do not really make much sense..........confused.com
mikeyb1983
Bump
BUMP......please guys any help would be appreciated.
ray671984
ray671984
Anything to do with wires i would take it to a proper auto electrician they will be able to tell you what its for or what it has been used for.
DDS789
DDS789
What about here
http://www.*******************/showthread.php?t=116419
Replace the stars like I said earlier.
Looks as though it's the 12volt ignition wire, the switch was probably an attempt at a security switch, possibly you had to press it before the car would start?
Seen similar attempts done before but on different parts that help to start the car like fuel pump etc etc
mikeyb1983
What about here
Ah nice one mate 12v ignition sounds good. The bit about a security switch would be good but i have never used this switch in the year or so i have owned the car! Weird......:wtf:
DDS789
DDS789
I bet you have to press the button to activate it.
Hence you never needing it. It may not even work looking at its bodgery lol. I'd I'd cut it out solder up and heat shrink it.
